Vailant Eco Tech 624
26 Aug 2007
Lancashire
HI
Still having problems!
Pressure drops over night and often prevents CH coming on.
I top up via the filler pipe so the pressure needle reads half way.
Heating comes on and the pressure rises into the red. I have tied a bag to the overflow and water collects into it.
Heating switches off at the designated time at night and the pressure drops again.
I have checked all the pipes with tissue paper and been under the floor. Whilst there is green corrosion around one fitting there is no moisture evidence / drips and I have looked at it whilst the CH is on.
I have one pipe inder a concrete floor (poor builder!!!!!) and cant check that for a leak, but there is no evidence of a leak - laminate floor is not springy etc.
Are there any other checks I can do? Advice you can give me to pin point the fault?
look up expansion vessel in F&Q
