I've been experiencing a lack of really hot water lately. Its not too bad, but apparently not hot enough for a bath for the Mrs (she seems to like 3rd degree burns!).
I've found that running the cold tap in the sink while filling the bath with hot makes the hot tap in the bath significantly hotter (to her indoors satisfaction). The boiler then cycles on and off while filling, which I believe is so that the water doesn't get too hot.
The temperature for the DHW is at max on the boiler. I had been told before that it can be a symptom of the CH circuit having low pressure, so I've topped that up with the filling loop up to close to 2bar. It does seem to lose pressure reasonably regularly, dropping to around 1bar, never to the point where the boiler won't fire up though. I've not found any leaks anywhere. There is noticeable scale around the heat exchanger, but I can't see any leaks or moisture anywhere, just dry scale build up.
Any suggestions?
Any suggestions?
