Assuming the filling loop is disconnected the only normal place for the leakage to occur will be within the plate HE.
You can do a final check by turning off the cold feed to boiler and opening a hot tap after setting the boiler pressure back to 1 Bar cold.
Thats quite a simple task to replace yourself if all the other bits are manageable, probably cost less that £50 to buy.
If the PRV is leaking at 2 Bar then it should be replaced.
We already have our agile-services.co.uk domain. All these Yahoo and similar look so unprofessional.
