vaillant 824 turbo max plus
2 Oct 2004
If the temperture of dhw is displayed at 62 c at display and 47 c at tap nearby could the temp sensor on pipe be defective ( or replaced with that of ch )?
Are the two sensors the same ?
thanks
temperature of dhw is displayed at 62 c
I thought the temperature displayed was the boiler flow temp., not the DHW temp., which would explain the difference.
I will have to check that chrishutt . The temp at display was checked before with tap temp , i think they tallied but now i am not sure :?
If anyone knows part numbers can they check if the temp sensors( dhw and ch ) are the same ? :?
thanks
*confused*
flow for 824 is 42deg rise at 8l/pm had one this week only 35deg rise turned out the mixer tap was letting bye bringing temp down
