vaillant 837 ecomax hot water temp fluctuating
14 Jan 2011
Hi all, have been having problems with the hot water temp fluctuating have checked DV and dose not seem to be letting by and heating is ok , can anyone help??
These models suffer big time with blocked rubber hose goin up to main ht exch give it a squeeze! If it's rock solid order a new one don't try an clean it they always leak afterwards ! When u look through it u will be amazed it everworked at all
this causes the hot water prob u usually find boiler fires ok then just gradually dies to low rate gas an the temp gauge goes lower an lower , it doesn't show any fault codes
the temp fluctuates hot and cold and sorry its a turbomax not a ecomax
