    Dismiss Notice
Vaillant Combi pressure loss.
Discussion in 'Plumbing and Central Heating' started by whistler, 13 May 2019.
  1. whistler
    whistler
    3 Jul 2006
    190
    Thanks Received:
    2
    Country:
    Boiler is a Vaillant combi turbomax 824. Over last couple of weeks has been losing water pressure requiring a top up every few days. Have checked all radiators, taps and visible pipework, but no sign of any leaks. However most of the pipework is below floorboards so cant be checked.
    Is it likely to be anything in the boiler? I'm thinking expansion vessel. Before I call in the heating engineer, anything I can check to identify whether it's the boiler or pipework?
  2. Sponsored Links
  3. Gasguru
    Gasguru
    9 Sep 2005
    12,250
    Thanks Received:
    3,249
    Sussex
    Country:
    Check the safety valve pipe outside...
  4. ianmcd
    ianmcd
    15 Aug 2010
    22,834
    Thanks Received:
    9,250
    Lanarkshire
    Country:
    you will have an outlet pipe from the Pressure releif valve , it should be outside , tie a ballon or freezer bag or the likes over this outlet and see if it collects any water
  5. whistler
    whistler
    3 Jul 2006
    190
    Thanks Received:
    2
    Country:
    I set the pressure to about 1.5 bar and fired up the boiler and it quickly rose towards 3 bar so I'm guessing its the expansion vessel?
  6. ianmcd
    ianmcd
    15 Aug 2010
    22,834
    Thanks Received:
    9,250
    Lanarkshire
    Country:
    well you are guessing rightly
  7. whistler
    whistler
    3 Jul 2006
    190
    Thanks Received:
    2
    Country:
    Followed the procedure to re pressurise the ev and tried again but the pressure still rose to 3. So looks i need to get the engineer in to fit a new ev. Just curious, as the ev is behind the boiler, does this mean a removal of the boiler off the wall? If so, I guess it is a expensive job. I have been thinking about a new boiler later this year, but if it has to come off the wall, maybe I should get it replaced now.
  8. Sponsored Links
  9. ianmcd
    ianmcd
    15 Aug 2010
    22,834
    Thanks Received:
    9,250
    Lanarkshire
    Country:
    because you never drained the boiler and left the drain point open when re-pressurising the boiler, if you dont follow all the steps there is no point in starting
  10. whistler
    whistler
    3 Jul 2006
    190
    Thanks Received:
    2
    Country:
    ???? How did you work out what I did and didn't do? I said I followed the procedure which commenced with draining the boiler.
    I'm now thinking an external low cost expansion vessel may be my best option until I get a new boiler installed.
  11. That is his MO.....Jumping to ridiculous conclusions out of thin air.
  12. ianmcd
    ianmcd
    15 Aug 2010
    22,834
    Thanks Received:
    9,250
    Lanarkshire
    Country:
    Because if you had followed the procedure correctly, you would not have been able to pressurise the vessel if it needs replacing
  13. ianmcd
    ianmcd
    15 Aug 2010
    22,834
    Thanks Received:
    9,250
    Lanarkshire
    Country:
    Keep reading dipshoite you might learn something
  14. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
