Hi all,
I'm a user of a 831 (it's been fitted in 2010) and started having issues with it recently. I'm not qualified in boiler repair but have done a few days' research and this is what happens with mine:
Started by throwing an F75 now and again but worked fine after a reset. When they became more often I called the gas man who installed it, and he swapped the water pressure sensor. First one he fitted thrown the boiler into F73 straight away so he replaced (the replacement) sensor with another new one - no errors with this one, quickly checked boiler operation - just turned a tap on for 1 minute, had hot water coming out and left. I thought it's all good until I tried taking a shower and noticed hot water was coming out freezing cold then hot for a few seconds then cold for a minute and so on alternating. Boiler seems to work fine on CH but didn't have to use it due to outdoor temp at the moment. Now it throws F23 errors which you can reset but still have the alternating DHW temp issue.
Based on previous posts by Agile and Bunnyman I've gathered some more data hopefully will help - codes below:
d.22 = 1 when hot tap is on
d.36 = returns value according to flow rate
codes I found odd:
d.40= 40 - 46 centigrade
d.41= 61 - 65 centigrade
How can the return temp be higher than flow? is this normal?
When boiler produces hot DHW is showing S.14 but goes into S.98 after 20 seconds of producing hot water and burner stops although hot tap is still running.
I don't think my model of 831 has the canoe plastic filter that other ones have next to the water pressure sensor as couldn't see one myself or the gas man. The old sensor he pulled out had some fine black bits coming out if it.
Diverter valve has been swaped last year as was leaking really bad and now have the newer ones with the adapter fitted - DV seems fine, no leaks now.
Could someone please help with a suggestion as my gas man is puzzled, has no idea of what's wrong with the boiler - he has rung Vaillant and waiting for advice but it's been a long wait already - 3 days.
I live in Milton Keynes and would appreciate if any of the Vaillant experts (I know one lives in Northampton) would be able to book me in for a repair.
Many thanks,
codes I found odd:
Many thanks,
