Which should be removed after the system has been filled. Removing it will ensure that no more water can get into the heating system even if the valves are letting by when shut.
From that I assume it is a non removable piece of pipe. What ever happened to the sensible requirement for flexible removable filling loops. Or is there now implicit trust in valves to prevent CH water getting back into the nains supply ?.
Both loop valves are appalling quality..I replaced many and they often only last 18 months before letting by again. You're best off capping the valves and fitting an external loop (and disconnecting the hose)
I have just spoken to the engineer who called Vaillant technical who told him he has done everything they would expect to solve the problem. The firm are now paying Vaillant to come out on Friday and hopefully resolve the problem!
Yes, the pro is the no-frills bargain basement version of the Ecotec, and needs an external filling loop. The Plus has one built in to the isolation valves
Yes Vaillant came out and sorted the problem. It was the filling loop and the noise was from diverter valve. Engineer changed both and since then had no problems at all.
