Vaillant Ecotec plus F22
15 Mar 2018
My boiler was showing F22 fault, so i sorted that and top the boiler up as the pressure had dropped, but then i noticed it leaking so it gradually empties and the F22 fault keeps showing, any ideas on why it is leaking and if i can sort it???
Cheers
You've got a Vaillant...they can leak from many places...diverters, pumps, etc
Hi, its not leaking from any pipes visible on the outside, its coming from a small hole on the underneath next to a pipe, i would have to take a picture really, the is meant to be there its not a hole that has appeared on its own
Would recommend you call a GS Plumber if it's coming from within the boiler.
