- Joined
- 29 Jan 2007
- Messages
- 40
- Reaction score
- 0
- Country
Dear all I have the following problem and would welcome your support. I have a combo boiler as described in the title. This morning I noticed that it was wet below the boiler and I then noticed dripping water from the underside of the boiler. I opened the access panel and saw that the pressure gauge was off the scale beyond the red zone! I searched the website and found someone with a similar problem was advised to ease the pressure by draining water out at one of the radiators. I followed this advice (after purchasing a key) and hey presto pressure reduced from circa 2.6bar down to 1.2bar. Dried under the boiler, no leak present! Went out for the day came back and checked under the boiler, you guessed leaking again. Opened the access panel and checked the pressure, 3bar! So, once again drained to relieve pressure back down to 1.3bar, leak stopped and all well.
Can someone please tell me what is going on when a 'closed' system on it's own accord manages to double in pressure? I'm clueless what to do over the weekend however cone Monday I will be calling on my vaillant service contract to help. In the mean time I'd rather minimise any damage.
Many thanks in anticipation for any support, by the way as you've probably guessed I'm not a plumber,....
Regards, Kevin.
Regards, Kevin.
