- Joined
- 19 Mar 2007
- Messages
- 727
- Reaction score
- 5
- Country
hi guys - i had a vaillant ecotec 831 installed in august 2012, regularly serviced, and working perfectly so far untill recently when i took 3 radiators off downstairs to wall paper the rooms, done all the decorating put the radiators back on, filled up the system to bar 1.3 , but got a "f75 water shortage at pump" error...so i bled all the radiators, checked pressure , left boiler off from the mains for about 10 minutes..then turned it back on everything worked fine hot water and central heating, today i got that "f75 water shortage at pump" error message again....checked rads for air , checked pressure 1.3 fine...left the boiler off again for a short while and is working again but i can hear a rumbling kind of sound coming from the boiler when its working...is there air trapped in the system ?..do i need to reset the boiler in anyway..any help would be great cheers..
