Vaillant gas boiler fault
13 Oct 2009
Derbyshire
Hi , My vaillant eco is roughly 10 years old and as started regularly to get this fault Number on it ( fault 23 ) it clears when I reset it. Does any one know what this fault refers to.
Manual says
Water shortage, temperature difference between flow
and return NTC too large
Pump blocked or defective, pump output too low
Could be low on water or pump is going or system is getting blocked up..
OK,
Thanks for your help, it has just done it again. Seems to be getting worse by the day
