I have a Vaillant VCW 242EH and for a while now i have been putting up with the problem of the domestic hot water supply being just too hot, it is unbearably so. I have set the temperature selecter valve to the lowest setting (still boiling hot). I did increase it to the three setting to check that the water section is tripping the servo control valve and therefore the microswithches and it does, it also goes back after the water has been turned off.
I do have a slight leak on the water section and on the domestic heat exchanger which does look a mess rust etc.
Could there be a problem with the D.H.W thermostat or could it be due to the heat exchanger?
Any help would be welcome as it has been a good boiler.
