Vaillant Sine 18 T3
14 Sep 2009
London
Hello all - following on from a previous thread re my boiler ( which Agile/Tony thankfully sorted )
The DHW is only tepid with the flow valve screwed out and hand hot with the valve screwed in. Also the DCH makes the radiators hot but not as much as they used to be. The temp dial reads 60 - it used to go upto 85/90 .
The burner flames are not as high as I remember them being. Gas hob/oven work as usual so gas supply seems OK.
I switched it off at the red rocker switch and wall,pressed black reset knob, relight the pilot light and pressure of system when cold is 1.0 bar.
Any thing else I can look at or any suggestions gratefully received.
Alex
