- Joined
- 4 Dec 2015
- Messages
- 4
- Reaction score
- 1
- Country
Hello Folks
Hope you can help me?
I have a Vaillant THERMOCOMPACT VC GB 242E
The control panel is a Lifestyle LP722
Unfortunately Packed up.
Symptoms:
No light on the boiler Rocker Switch in ON position.
If I remove the 2A Time Delay Fuse on the right hand side and insert it back in the boiler seems to momentarily come on for approx 1 second then turns off.
If I set the LP722 timer to ON on the heating dead nothing.
If I set the LP722 timer to ON on the water I hear (likely a pump) activate but no heating.
The history of the situation I am in.
Called local plumbers (whom are friends of mine) who were very quick to respond ie last night (after work) and helped me go through the basics such as getting the pressure to the correct level. checking all the fuses (i had already done this but no harm in a re check with an experienced eye). we checked the motor was spinning and he said all the obvious things seem to be working. suggested it is likley something BOARD related but could not guarantee this statement without further investigation.
The idea of the late night appearance was to try and help me if it was something obvious unfortunately it appears not. They can of course fix this issue but it needs booking in properly and right now they are MAXED, there are a lot of very RICH demanding clients around gloucestershire demanding their time paying a LOT more money that I have so im sure you can picture the scene .
Ideally on the basis we have no heating or hot water atm I thought i might ask on the forum and see if someone can spot anything that might help?
A bit about me I have limited experience with boilers but do have a lot of experience with electronics down to a design level and also have sufficient soldering skills + equipment.
Anything on the electronics side I can TEST, desolder, what ever you need me to do. I am also pretty good with tools etc.
I am willing to listen to any advice anyone may have.
YES i do understand the risks of messing with gas related equipment but I think in this case it might electronics so possibley something I can do. Even if its not im happy to have a go if its defined as not too risky or silly.
From the advise I was given I have already pulled the board out which is a motherbaord consisting of x3 modular modules. Broken down as follows:
Likely to be the following part numbers. I have IDed the boards using Ebay listings as a guide so please forgive any errors or mistakes.
Motherboard - PCB130241
Fan Module - PCB130451/130395
Flame Supervision - PCB100555
Electronic Regulator - PCB252957/252958
I of course have no experience of this board but can spot any obvious signs of issues.
My attention was drawn to the Fan Module PCB where by the RELAY K3 had accessive carbonisation. Likely caused from long term switching and eventually arcing. I desoldered this RELAY and cleaned it up, cleaned up the contacts etc. Then tested using a 24V lab PSU with a 1K resisitor across the switching coil. relay fired up fine and noticed about 5ohm across the load line. so resoldered hoping that might fix it. Whilst I was at it I re capped all the solder joints incase of dry joints etc and momentarily blipped out the components populated on the board such as the x4 transistors, x5 signal diodes, x4 1N4007 diodes, x2 other relays, rectifier, x2 220R power resistors. the caps i just tested for shorts did not desolder due to time. however this board is LIKELY now in good shape. unfortunately re plugged still same symptom.
Motherboard, Flame board and Electronic Regulator still un tested. no obvious signs of damage.
The plumber that came round last night commented there was no spark perhaps my attention should now be drawn to the Flame Board? looking at these boards they are pretty simple and even without any knowledge of their functionality I reckon I could test it down to a component level IF REQUIRED. Of course we all value our time so wish to avoid any unnecessary testing etc.
anyway thats where im at. I hope someone with a LOT more experience with boilers than I have might be able to point me in the right direction. Or at least make some suggestions.
im all ears. many thanks.
Symptoms:
