Hi, I need some advice; I have been looking though the posts over the past few days and can’t seem to find the answer to my problem;
I have the above boiler which is around 7 years old, was serviced about 18 - 24 months ago and had lots of parts changed due to hot water problems, only had hot water every now and then and had to reset bolier.
It has been fine until the past couple of weeks, CH is great, but the hot water will only heat up to around 58 degrees and not matter what I set the temp to will not get any higher.
Can someone tell me if this is the diverter valve issue that seems to happen a lot or the heat exchanger?
I have not turned off the system to see if the rads get hot as the wife won’t let me!
Sorry if I am asking an obvious question.
Appreciate any help or advice?
Thanks.
Thanks.
