vaillant vcw gb 242e
19 Oct 2009
London
Central Heating working, but hot water taking long time to come and hot water is only warm is this the diverter valve ?
It all depends on when the boiler fires up! Should be within three seconds of tap on.
More likely to be a blocked secondary heat exchanger!
Tony
Boiler does switch and makes some clicking relay noises, hot water comes eventually after running water for long time.
Hi
Replace the microswitch on the servo valve. Common fault. Possibly easier though to replace the servo valve complete while you have it out.
Bunny
Thank you The831Bunny it was microswitch on servo valve..
:D
