J
jimalad
I've recently had the following installed...
ecoTEC Plus 624 System, VR65, VRC430 & outside temp sensor, Telford Tempest solar unvented cylinder + solar collector/controller/pump.
My installer has used a traditional thermostat mounted at the level of the boiler loading coil to provide feedback to the VR65 that the water is up to temperature.
I've noticed that when the boiler heats the domestic hot water, the loading circuit flow temperature is a flat 80 degrees celcius. I know that the boiler is capable of modulating its burn and wonder if I can swap the thermostat for a VR10 temperature probe instead. They seem inexpensive (£10). It could be inserted into the same cylinder dry pocket that previously held the thermostat. If this change were to be made then I presume that I'd then get the cylinder temperature reported on the VRC430, I'd be able to set the DHW demand temperature via the VRC430 and I've also read in various posts that there might be a DHW 'boost' feature unlocked, but maybe that's not the case? Essentially I'm interested in increasing the system efficiency and the way I have it set up right now just seems illogical to me as there's valuable information about cylinder water temperature that the control system cannot make use of.
I've read in this thread that a VR10 has been installed with VR65 on a non-Vaillant cylinder. In the same posting though, I understand that they still employ a secondary over-temperature fail-safe mechanism that uses a traditional thermostat that shuts the loading coil valve in case over over-temperature. Is this really necessary? In this thread, there's discussion about whether the VR10 feedback method meets regs in the UK. Is the fail-safe control of the valve a way of clarifying this grey area, or would a pure Vaillant VR10 / Unistor installation still be fitted with this kind of failsafe as best practice?
I'm going to get my installer back to make this change, if it's turns out that it's sensible. I want to be super-clear to them though about the spec so there's no misunderstandings. Any thoughts?
James
James
