Shows very basic misinformation and misunderstanding which have been pointed out to this troll severall times.there is no economic functioning of an on-off thermostat.. it has to over heat rooms to shut down, and then when every thing has cooled down it has to work pretty hard to replace lost heat quickly...
It's Alec's nonsense, yet again.
Overshoot is less than half a degree if it's working properly. The last one I measured was much less than that. The boiler cycled with the stat at minimum modulation, as expected.
Remember that the seasonally adjusted efficiency of a fully weather compensated system is only 2-3% better than a plain condensing boiler. That's accepted by even the most ranting manufacturer.
That assumes it's set up perfectly, which very few are, which is why there's a long history of weather compensated systems being disabled, or maladjusted so that they run just the same a non-compensated system would. That's the most common set-up, unfortunately.
Alec repetitively tells fairy stories to support his irrational obsession.
Unfortunately he doesn't seem to understand much about how many heating systems are controlled.
Several of us have tried to educate him but he doesn't learn, or pretends not to. It doesn't suit his mantra, or the way he flogs boilers.
We have to assume the misinformation is deliberate, he can't be that "limited".
