Hi All,
Been reading threads here and learnt a lot about my Ecotect Plus 824 boiler. Issue is this....
Removed a couple of rads to take down a partition wall. Fell over onto one of the remaining radiator upstands! Seems I cracked a join under the floor as well as my arse when I landed on it. Didn't realise this at first. Got low pressure F22 and used filler loop (braided hose) to top up to 1.8 bar. Dropped to 0.7 bar overnight. Now found cracked pipe under floor. Water pooling but not an emergency issue as loads of space to drain away. Have now turned off boiler as it can't maintain pressure and I was worried about leaving it on. Can manage a couple of days with no heating or hot water as boiler didn't like just being asked for hot water with central heating turned off (gave me a F75 code as no pressure change deteced - understandable I guess) Plan to reconfigure rads on Wednesday or at very least fix pipe issue with a cut and end stop solution. Question is on refilling. Obviously system will have drained out more or less completely. can I just turn on boiler and then use braided hose filling loop followed by extensive rad bleeding exercise or do I need to refill somehow BEFORE firing up the boiler. Is there any difference between using the filler loop describe and using the grey knobs under the boiler. My reading is that they can be a bit fragile and I'd rather not use them if I don't have to.
Thanks in advance for your advice.....
Simon
Simon
