Vailliant sustain 418 heat only problem
Yes, which can most often be taken from the wiring centre.
Granted there are setups where pump is elsewhere, but not often.
Other boilers such as Main do not require a permanent live and/or pump overrun as their hex dissipates heat via the fan or just doesn't get too hot.
Vaillant have pcb firmware that requires very tight limits from NTCs to protect the hex which is vulnerable due to design and construction.
Well that's annoyed me as I was originally putting in a Main ha
OK. Then, imo you can utilise the 3 wire kit, but I've not had the benefit of eyes on your system so... It's all advice at distance! ;)
Thanks. It would take abit longer to sort even though if knew how to do it I would go down that route.
Got my spark friend throwing the cable in tomorrow for a £100.
