Hello all
I have just moved into my first flat, as it is freezing first thing i done was turn on the heating, this fired up ok, and heated the radiators. about 15 mins later they all went cold and the boiler was totaly dead!
the internal fuse in the pcb had blown, this was replaced and the boiler then turned on.
now the water heats, the pilot light comes on but it then makes a loud banging and gurgling , and then stops, no hot water is pumped to the rads.
i have soemone coming to look at the boiler on tuesday, and knowing nothing about boilers, i don't want to be ripped off!!
could this just be air in the system causing the pump to run dry ? i have bled all of the rads but not sure how to bleed the boiler.
it also has since blown another of the 2a fuses.
any suggestions would be great!
james
ps , i forgot to add i cant find the model number ANYWHERE on the boiler. the boiler was ment to be serviced recently ( not sure if it was ) but the main PCB seems to look newer then the rest of the system (again told this was changed )
james
