- Joined
- 3 Jun 2019
- Messages
- 5
- Reaction score
- 0
- Country
Just signed up having searched for answers but not sure what difference my system has on things so... Apologies in advanced for the long post but I've tried a few things so have detailed them here..
System installed 2012 - new build - I am first owner.
Valiant Ecotec 615 Plus
Danfoss programmer
Santon Premier Plus unvented mains water heater
2 floor (zone) heating.
Issue - no hot water currently. Heating is fine - been noticing that our hot water supply doesn’t last us as long just lately.
When we moved in the builders recommend that we keep the hot water programmer on from 7am to 10pm, allowing the water to heat when required but I never liked the idea as felt like a waste of energy but also, we'd hear the boiler in or bedroom as its installed directly below in the kitchen.
So I re-programmed the timer to come on at 8pm every night for just an hour - this has lasted us fine since install - showers, washing up etc etc. I've only ever had to click the 1 hour override button a few times to top up if we've needed it.
Despite no other issues since then, we had no hot water one morning recently. I researched solutions and figured Id check the external expansion vessel - no pressure! A quick push on the valve and nothing, no air, no water (which might indicate it was faulty). So I shutdown the water, ran a tap to alleviate any pressure and pumped up the expansion vessle to its recommended 3.5bar. Hit the hot water override and the boiler fired, and we had really good hot water - much better than usual, obviously! Felt great to fix the issue, brownie points etc although slightly confused why the expansion vessel would cure this issue as figured it was more for the heating system....
This has lasted about a week however as last night, despite the usual 8pm heat up, when my partner went for a shower about 2 hours later, there was no hot water. She was not happy!
This morning I checked the expansion vessel again and this showed 2.7bar, down a bit from its recommended 3.5 so I hit the 1hr override - but the boiler did not fire.
I tested the heating - worked fine, which means the boiler is ok as I understand it - is that right?
When I press the override button I can hear the zone value working.
As the weather is so warm, our heating isn't on at present and programmer is set to manual - but this cant have a bearing as its been like this for several weeks now.
I've also read that this particular boiler doesn't heat the water - which would seem right as there is no "tap" symbol on the boiler display, only a radiator symbol. I've always understood this to be the case but what confuses me is why does the boiler come on when programmed to heat at 8pm, and when I hit the override? I understand the Santon heats the water but how does it do this, what relation does the boiler have to it?
So I believe the boiler is ok, the expansion vessel and programmer - so it must be the Santon - but what could it be?
Please can someone advise what the issue might be? I thought I had it sussed by pressurising the expansion vessel (although must admit I wasn't sure why this would make a difference - but it did last week) but with that seemingly ok (despite being down a tad), we still don't have hot water.
Many thanks in advance..
Danfoss programmer
