I think there may be a bit of a compatibility problem here....
Checking the M&I for the TS120 timer, it talks about the Turbomax (NOT Ecomax 635 System Boiler) and as far as I can see the hot water control relates only to the 'Aquacomfort Warmstart' feature. (Since you presumably would not want to turn the hot water on a combi on and off anyway.)
As Danny points out, there are only 4 pins on the back of the clock and only one mains-voltage 'room thermostat' connection on the boiler tagstrip. I don't see anywhere an output to allow the timer on a system boiler to control an external HW zone valve.
All the references in the M&I to programmers seem to relate only to external ones of various makes and NOT to the Vaillant TS120.
I don't think the duff reference would be relevant, even if it did exist!
All in all, I vote the M&I for the 'Clear as Mud' award!
Re: Setting up gas valves on Turbomax. I once saw a succession of BG Service vans turning up day after day at the same house. Finally, a Vaillant van was there and the engineer emerged as I came past. Couldn't resist my curiosity, so asked him what was going on. Apparently, first engineer mis-diagnosed a faulty gas valve and changed it. Boiler went ape-sh*t. Second engineer (correctly) diagnosed faulty air-switch and changed it. Boiler still turning somersaults. Third and several more engineers struggle on. Eventually, Vaillant called out and in less than 10 minutes engineer finds new gas valve is SIT, original was Honeywell (or v.v. - quite legitimate) BUT gas-valve-selector jumper on PCB not moved over by Engineer #1! Prolly, that's what Fritz was referring to.
