The above boiler appears to function correctly but I have no heating.
There is plently of hot water, no fault codes, pressure is stable at 1.5bar, boiler fires and pump spins when the heating should be on but no hot water seems to go to the radiators. I can see the pin move in the DV when I turn the hot tap on and it is less than one year old so assume that it works OK. The heat exchanger has been descaled recently.
Having read through all the posts on here and other sites, I thought it may be something to do with an airlock somewhere so I have tried bleeding the pump by opening the screw on the front, as well as the radiators but no luck. I also have a Magnaclean which I have cleaned out and bled through the valve in the top after.
Any ideas what do next?
Thank you.
Thank you.
