Valve to radiator connectors name ??
14 Oct 2012
Essex
I am trying to buy brass 1/2 BSP connect that connects valve to the radiator . All radiator valves come with them but I can't find them on there own , can't even fine there name . I have restore some victoren brass valves and just need them to finish any one help plz
Not sure if this is the correct answer if you are looking for the part from the rad valve to the rad they are called Tails but your question is very vague try posting a pic and point which part you want the name of
Radiator tails, you need to know whether you need 15mm straight or union type ones
thanks I have put in tail but it come up with the bit that connects the valve to pipe ..the bit I am after is the bit that connects the valve to radiator it has thread on the bit that goes in to rad and rounded on other end with a nut that connect to valve
Its still a rad tail, mate....screwed in via hexagon flats on the outside, or likewise on the inside (large allen key needed!)
John :)
Have a look here. If you contact the company they might be able to help you. Other than that, you might have to buy a complete fitting and discard what you don't need.
I have thought that but I need brass ones and buying brass valves would be costly I can't believe it's so hard to find them it's mad
I expect to be ridiculed here, but aren't a lot of those brass anyway? Getting them polished to shiny is the issue, surely?
they are brass but been chrome plated so no good as its a bitch to get off
Depending where they're manufactured, maybe the company will be able to supply you with some which have yet to be plated?
Doesnt matter how many times you post mate they are still called Tails have never seen them sold seperate but not expensive anyway as part of a complete valve
what ..not expensive what's the cheapest set of brass valves then £10',,,,,£20 I need 10 sets yes very expensive :rolleyes: ..some one must sell them I am not just going to throw money away and give up
