vapour control layer
18 Oct 2013
London
Does a VPC layer include the silver foil sides of a kingspan / celotex insulation board?
Yes, although you should tape it to avoid anything blowing through at the joints
huh? if the boards are touching side by side, how can anything blow through it, there's no gap?
Shrinkage, movement, site cut edges, imperfect alignment, small items stuck between, warping, etc
If the joints aren't taped, water vapour will find its' way in through the gaps (even if they are very small) because water vapour is very penetrative.
