Varilight Remote Dimmers
21 Feb 2006
Manchester
Hello All,
New member here and I am hoping you can help.
I have fitted dimmers before so thought I would give remote dimmers a whirl. Boy I wish I hadn't!!!
I have the Varilight Remote Dimmers (Master & Slave).
I have looked at the instructions in the pack, TLC and in various topics on these forums but I am still totally confused.
My living room light is currently controlled from 2 separate switches which are configured as follows:
switch 1
Red >>>> Common terminal
Red/blue>>>> 2 way terminal
Yellow/black (with red sheath) >>>> 1 way terminal
Switch 2
Red >>>> Common
Blue >>>> 2 Way
Yellow >>>> 1 way
Anyone any idea how I set up my remote dimmers on the basis of the current wiring above.
Here's what it says on TLC.
http://www.tlc-direct.co.uk/Technical/DataSheets/Systems/TouchRemote.htm
Any help much appreciated.
Branny
Hi & welcome to the site
From what I have read, your master needs to replace your switch 1
Red= live
Red Blue = S
Yellow Black = Load
Slave your switch 2
red = live
blue = S
yellow = Load
If anyone see's it diffent, please shout!
Hello there,
Thanks for the info above.
Wired up as stated and works, BUT....
When I come to switch the lights off, if these are on full power they immediately come back on. If they are on half power and I go to switch off, they stay off. Have tried 2 different masters with same result.
Any ideas as to why that would be the case?
Branny
TLC said:
a) Touch Control
To initialise the dimmer, touch the circular sensor on the front of the plate once for 2 seconds. The dimmer will respond by making the light(s) brighter. A single touch will now turn the light(s) on or off. To dim the lights, keep contact with the sensor until the desired light level is reached. While contact with the sensor is maintained, the brightness will cycle up and down. To change the direction of the dimming cycle remove contact and then touch the sensor again. When the brightness reaches the level you desire, remove contact with the sensor. If you have a 2- (or multi-) gang model you need to initialise each sensor in the same way.
If you just single touch the plates do they go off and on?
Hello
Yes, single touch produces above results, ie if half power then stay off, if full power come back on.
Any ideas?
Branny
No idea's from here, I've never used those dimers. I hope someone else can help
As this has not produced any replies, I would suggest you contact TLC for their advice. It's wired correctly so it would seem like another problem
Still wired incorrectly!
First can you confirm the following:
Switch1
The Red wire connected to the common terminal comes from the same cable as the blue & yellow wires (3core+earth), and that the remaining red & black (2core+earth) are from a separate cable.
If this is the case the 2core+earth cable is the switch cable going to the light fitting assuming the Red is live and the Black is the switch return, wire as follows
Switch 1 (Master)
Red (3core) + Red (2core)= live
Blue = S
Yellow Black = Load
Switch 2 (Slave)
red = live
blue = S
yellow = Load
Hope this helps
