Various Myson Apollo Boiler failure, please help
1 Nov 2008
London
Hi there,
We have a Myson Apollo Fanfare 15/30 S. The central heating and hot water was running fine until we did a simple DIY job.
The problems started when we had to turn off the hot water to fix a leaking tap, and due to complications the hot water was off for a day.
When turned back on the hot water was only luke warm which then turned to cold. The boiler started making clunking/banging noises when the central heating reached the thermostat temp. and came off.
Next day we switched off the boiler and bled it. There doesn't seem to be any leaks. But now the pilot light will not ignite again and we have no central heating either.
Your help is greatly appreciated.
