As part of renovating our house, quite a few works have been done that I'm told don't need B.C. control, but I'd like to double-check whether I should consider approaching B.C. on any of these anyhow, in order not to risk a problem later on.
The house is 1930s terrace. Anything related to the Party Wall Act is already okay, and the work is to a high standard by a reputable builder, so for us this is purely about anything where we'd be expected to show B.C. paperwork if we sell.
Thanks!
- Suspended floor underfloor insulation blocks + breather membrane added.
- All walls and ceilings stripped to brick and re-surfaced (this one's still being done, but that's another story...)
- New central heating pipework + radiator mounts.
- Metalwork added in loft, to hold the cross joists to the main joist (joists strong but not cross-linked, they're all 2x4 or in some cases 2x8).
- Space created in 1st floor ceiling for a larger loft hatch by adding metalwork + doubled trimmer both sides to strengthen the nearby walls and joists, as I understand it, then removing a few feet of joist in the way. (New hatch will be fire resistant etc).
- 2 structurally significant joists found to be virtually unsupported and causing structural weakness to other elements, proper brickwork and new metalwork have been added to fix them both.
- Non-structural wall "moved over" 3 feet.
- Concrete-embedded drainage gulleys added alongside house wall, to guide rainwater along house wall to the drain (there weren't any before so water pooled up instead causing problems).
- Roof storage space has its own convenient tall access panel which had been sealed off, now replaced by firedoor and fire-resistant frame structure, accessible by 3 steps up. (Currently using removable steps in case fixing them triggers any kind of B.C. issue)
- Split level "gallery" added in a 1st floor room, with storage space under it. (Picture a 3 foot high battened area, with shelves below and enough space on top to put a beanbag or a few books and not be disturbed). Gallery area is small (<15% of floor space), "floor" of gallery is <4.5m from ground everywhere, foot of steps to gallery are <3m from midpoint of hall door, and all points on gallery <6m from hall doorway. Head space is >2m above the (short but steep) fixed steps, which can be replaced by non-fixed steps, or 42 degree steps, if required. Doesn't have any kind of separate door up there. Tried to comply with vague and murky regs in this area, they aren't as clear as they could be! Is any of this a problem or needing B.C. approval?
Thanks!
