We are wanting to demolish a wall between our kitchen and dining area to improve the space. Weirdly, the kitchen currently has two parallel walls about 550mm apart - both are single skin brick approx 10cm plus plaster (walls A and B in image). Wall A has a 1.2m wide opening that is used to access the space between these walls, which looks like it is supported by a door-level lintel above (yet to remove wallpaper and check). Seeing the alignment of wall A with another wall in the house, I'm guessing that wall B was added later on to enlarge the kitchen space, at the same time as the 1.2m opening in wall A was created - this last bit is guesswork of course.
View media item 64817
The plan is to demolish wall B and block the existing door between the kitchen and dining area = more counter space in kitchen and space for a family-size dining table
Checked under floorboards - joists run perpendicular to walls A & B and continue through both walls without any joints. Both walls sit snugly against the bottom of the joists. Does this mean that the parallel kitchen walls are/ are not structural, or is only one of them structural? If structural, is it possible that the structural integrity of wall A was compromised when wall B was added and the opening created in wall A?
We have a builder coming in next week to have a look, but just wanted to know what to expect. Are we looking at a complicated building regs procedure or is this simpler? Anything to watch out for? Thanks for any help and sorry for the long-winded description.
