I wonder if someone can help? I am fitting four en-suites in four different rooms, each one is going to have a mixer shower. I have been told to fit a 300 ltr unvented indirect mains pressure cylinder and fit a 300 ltr cold storage in the loft. I have measured 18 ltrs per/min of water coming in on the ground floor. I have been told that I will need 40ltrs per/min if all the showers are used at once. My concern is that if I use a mains pressure boiler, and the full demand is used the pressure will drop too low. Should I consider using a vented cylinder instead and use some shower pumps.
