Need some advice on constructing an internal wall (3830 x 3050) with Thermalite blocks, ensuring it doesn’t effect the ventilation. Just to say I’m not looking to create a wall of studwork.
At the moment we have a narrow L shaped hallway and I’m looking to widen it by moving one wall to make it completely rectangle. The wall has been inspected by a builder and an architect who both confirm it is not load bearing. As you can see from the pictures our bungalow has a raised wooden floor resting on sleeper walls. My main concern is ensuring the new wall wont effect the current under floor ventilation. How would I ensure this is the case? Would I need to create a partly honeycomb wall below the flooring joists to allow the air to flow? Being as this would effect its strength would I need those to be of hi-strength Thermalite blocks with regular blocks above?
As for the foundations, would building it directly on oversite be sufficient? I ask this because I have no idea how deep ours are.
I’m only a regular DIY’er so any useful help would be welcomed.
Thanks in advance,
Robert
Thanks in advance,
Robert
