vertical crack between front door and first floor window
13 Sep 2009
Good afternoon everyone.
So a while back I noticed a vertical stepped crack, following the mortar line appear between the front door and first floor window, which was mirrored inside the house. no bricks were cracked at all, it just stepped up following the mortar. It was only a very narrow crack, maybe 8-10 bricks high, not very wide at all.
so a few months ago I got a diamond blade and chased it a couple of centimetres deep, then repointed it. A hairline crack has appeared again so am looking at alternative ways to fix the problem, possibly a crack stitch rod?
I don't think it is anymore than settlement, as we had a first floor extension a couple of years back and the crack doesn't appear above the window, only below it. The crack also isn't mirrored at the back of the house, no problem opening and closing windows or doors and it doesn't appear to twist at all, just a hairline crack.
So would a crack stitching kit be a good solution? Probably 2 or 3 one metre long stitching bars, polyester resin and then repoint. I really would prefer to get someone in to do it but guessing it would cost a fortune, not sure if anyone has an idea of what it would cost.
I could probably do it myself if need be.
Any advice is appreciated.
Stitching is not fixing the problem. You need to determine what's causing the movement and deal with that, as that is the problem.
the problem is most likely settlement due to the first floor extension a couple of years ago. the crack only appears between the door frame and first floor window so pretty sure it's not subsidence.
