Vertical radiator divertor
18 Feb 2006
Birmingham
Hi all
Just fitted a vertical rad with an in-built divertor and after piping up I think I’ve I got flow and return mixed up as only the bottom is heating up, so bypassing the divertor
Can I drain and fit an a divertor on the other side to fix this or do I need to re-pipe this?
Thanks in advance
Is it a double and does it use separate U shaped brackets? If so then, just spin it around 180 deg so the inlet and outlet are swapped around, the top stays at the top
