I've a problem with the CH in my house that I moved into five months ago - so not much history on the system. It is open vented, fully pumped Y-Plan, with an Ideal Standard NF50 boiler, 11 rads, HW storage tank.
When I moved in the rads were only heating up at erratic times and the HW was RED hot regardless of tank stat setting. I traced this to the zone valve actuator, replaced it, problem solved. I also fitted a Honeywell CM907 room stat to replace the existing cheapo unit. I've got one small rad removed at the moment and one turned off at the rad valve in rooms that I'm decorating. When I took the one rad off I remember it struck me as having a lot of black sludge in it. I've noticed that there is generally a lot of air in the system which accumulates in the bathroom rad which I bleed at least once a week with loads of air coming out.
The problem: About a month ago, the heating turned on at the programed time (from cold) and there was a loud banging noise a bit like someone kicking a tin can down the road. After about 30 secs there was a gush of water from the header tank overflow, loads, at least a whole tank full I would say. The system then ran normally. As a result of this I turned the pump speed down from 3 to 2 thinking that the problem might be "pumping over". This Sunday the system turned on at 7am and the tin can noise started up followed by the gush from the overflow and then followed by some really loud cracking and banging noises. I mean REALLY loud. After they stopped there was loads of gurgling noises coming from the rads for about an hour. Then everything was back to normal.
I've checked the layout of the system as best I can (pump position in particular) and it seems OK to me. I've yet to look inside the header tank. I don't know if removing the one rad and turning off the other has started this problem as I haven't been in the house long enough to know if it was happening before. It might have happened lots of times when I've not been in. I've done some other plumbing round the house but all on the water side, not heating (fitting a new bathroom, shower pump, essex flange etc)
Any ideas? I suspect maybe a blockage somewhere?
All advice gratefully received.
Cheers.
Cheers.
