Very loud noise when hot water is run
16 Apr 2007
Manchester
Hi, my problem is similar to others on here but not identical so I would like to describe exactly what happens. Hopefully someone can help.
I have just bought a flat (approx 5y old). There are no radiators, the hot water tank just supplies the taps. It is not a gas bolier, just a hot water tank heated by 2 immersion heaters.
When I run hot water, after 10 secs or so I hear a really loud noise. It sounds like a fog horn coming from somewhere near the tank but I can't identify exactly where.
I think it is related to the water re-filling the tank as it does not start immediately and continues for some time after I stop running the water.
I am not sure if this is related, but if i run the hot water for a long time (fill a bath), I get the loud noise and then the flow rate slows right down. It seems like it takes a few days to recover the normal flow rate.
Any help would be very much appreciated. Thanks
Sound's like the problem could be the ball valve which feed's your CWS tank. If the sound is definatly coming from the cylinder, and seeing as you live in a flat i would presume the tank maybe a fortic. This means the tank which fill's your cylinder is built into the top with a lid on top. If this is the case, this is where you will find the ball valve, probably just need's a clean and a new rubber?
HTH Sam
