    Dismiss Notice
Very slow leak in gas heating system - looking for seal recommendations / advice
Discussion in 'Plumbing and Central Heating' started by stephenco, 5 Mar 2018.
  1. stephenco
    stephenco
    11 Apr 2013
    38
    Thanks Received:
    Belfast
    Country:
    I've a 5 year old gas heating system which I have to pressurise every few months and which I'm assuming has a very small leak somewhere.
    I've searched but can't find it. Someone told me I could add some sort of sealant which may cure it. Can I ask for advice please.
  2. Sponsored Links
  3. terryplumb
    terryplumb
    8 May 2017
    4,298
    Thanks Received:
    878
    Country:
    Don't put leak sealer in the system. It can cause more grief. If you only top up a few times a year ,don't worry about it.
    • Thanks Thanks x 1
    • Like Like x 1
  4. CWHEATING
    CWHEATING
    6 Mar 2018
    169
    Thanks Received:
    18
    Country:
    LOL micro leaks. Bane of my existence. I’ve found most the time pressure is being lost from small leaks in boiler. Get qualified engineer to remove casing and look for any small signs of water damage/leaks. Usually it’s to do with auto air vents leaking slightly then drying up due to heat produced by boiler, it usually leaves a water residue that looks like a crust. Or it could be to do with various boiler seals. Another thing check radiator valves or radiator bleeds. Slow leaks usually dry up before showing any signs of actual leakage. Also another reason for lost pressure is air in the heating system working it’s way round then to your boiler and released out of the auto air vent on boiler. How old is your boiler and how old is your heating system?
    • Like Like x 1
  5. stephenco
    stephenco
    11 Apr 2013
    38
    Thanks Received:
    Belfast
    Country:
    All good advice Cwheating, thanks for this. The gas boiler was installed around 5-6 years ago but the pipework and rads are around 30 years old.
  6. ianmcd
    ianmcd
    15 Aug 2010
    16,983
    Thanks Received:
    6,431
    Lanarkshire
    Country:
    I wouldnt worry too much about having to top the pressure up every few months and as correctly advised dont put leak sealer in , it cases more harm than good
    • Thanks Thanks x 1
  7. m0t
    m0t
    23 Oct 2006
    392
    Thanks Received:
    11
    Country:
    I just added some leak sealer to my system, what sort of issues does it cause?
  8. Sponsored Links
  9. ianmcd
    ianmcd
    15 Aug 2010
    16,983
    Thanks Received:
    6,431
    Lanarkshire
    Country:
    If you have a modern boiler some of the waterways are very small and leak sealer can block these, it also jams some small moving parts within waterways, if you have a leak fix the leak, dont turn your system water into mud.
    • Thanks Thanks x 1
    • Like Like x 1
  10. CWHEATING
    CWHEATING
    6 Mar 2018
    169
    Thanks Received:
    18
    Country:
    Because your system is so old then pressure loss is to be expected. Until you see a dramatic loss in pressure then everything should be ok just topping up the pressure when needed. It’s always a risk when replacing old boilers on old heating systems to go for pressurised boilers.
    Like the other guy said sometimes these leak sealers can do more harm than good. Probably best to drain your system and add some inhibitor.
  11. TicTac
    TicTac
    21 Feb 2018
    391
    Thanks Received:
    68
    Country:
    Have a look at the overflow pipe from the PRV, and see if there's any signs of a leak; fit a clear plastic bag over it if in doubt, and see if any water comes out.
  12. chrisw99
    chrisw99
    5 Apr 2004
    157
    Thanks Received:
    13
    Cheshire
    Country:
    I recently had a new boiler fitted and it says in the manual it is normal to top up the pressure every few months because the pump in the boiler expels air present in the system over time.
  13. CWHEATING
    CWHEATING
    6 Mar 2018
    169
    Thanks Received:
    18
    Country:
    I haven’t topped up my boiler for 8 months now and the pressure gauge still sits a 1 bar when cold. Perfect.
  14. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
