Very small kitchen window replacement
28 Aug 2004
Cheshire
I am looking at replacing a small kitchen window wood frame, with a new uPVC window.
The existing window does open, but i'm not too fussed on replacing it with an open type.
The external measurements brick to brick are 760mm x 370mm
Internal brick to brick is 730mm x 330mm
I know this is pretty small so would prefer to just order and fit myself instead of getting a company in to quote and fit a window so small
Where would be the best place to order online maybe, it only needs to be a budget window
Cheers Steve
If you can find a local window manufacturer I am sure they will be only too happy to make you it. You should probably drop a hint that you are going to get a price also from a rival firm to encourage a good deal from them because right now I'm sure they they will be glad of the work .
I know it’s a PITA but ALL replacement windows must either be fitted by a FENSA registered installer or notified & inspected by your LABC (fee involved). Building Regs. also require that replacement windows do not make the situation any worse in terms of ventilation or escape (admittedly escape might be tricky through a small window anyway). You need a certificate of compliance for the new window through either of the above routes but if you can’t produce it when you come to sell up, you could have problems!
AS DABZ says, a small local company will probably be grateful of the work right now but make sure they are registered or will obtain a certificate of compliance from LABC.
Thanks for the info
It may be best to get a local formto do it, my time and materials etc it may well end up cheaper for me anyway
