Very Small Shower Tray..?
22 Feb 2007
Cheshire
I've been asked to supply and fit a shower tray that is only 670sqmm. I can't find one that small in the usual places I look. The enclosure is completely built-in so I can't fit anything bigger without knocking a wall down. Does anyone know where I might find such an unusually small shower tray?
Thanks in advance.
You may find that caravan shower tray is very light and flimsy, and may require a lot of additional support to stiffen it up for use in a domestic situation.
Many caravan parts are designed to be as light as possible.
The waste outlet may be a non-standard size as well.
Cheers Tickly.
This shower is only used occasionally and I did warn the customer it's designed for caravans before I ordered it. I've also assumed the waste will be 40mm because it has to be a certain size to avoid blockage/flow problems, whether it's in a caravan or not.
We'll soon see...
