I had a bedroom extension built including an en-suite.
The builder took up the old wood block flooring which was found under the old carpet.
This has left the en-suite floor as the bitumen coating which was used to stick the original wood block flooring down.
The builder said that there was no problem mate just put vinyl on top (as the floor was level).
The vinyl stockist however tells me that the bitumen will bleed through and stain the vinyl.
Is this correct, and if so is there any product that I can seal the floor with.
Whatever the solution it must not be thin as the sanitary ware is already in place, and shower trims etc. will not fit if a thick coating is used.
Cheers
Cheers
