Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
They use good quality foam filled coax cable like WF100 with crimped on F connectors.
I think the cable Virgin use is made by Webro but any good quality screened coax will be fine, Normally sold as satellite cable.
Forgot to mention the cable sold in DIY stores as satellite cable is normally RG6 and id avoid this for cable, Also dont be tempted by the cheap low-loss coax cable its no good.
In a nutshell no you cant, the freeview signal isn't broadcast over the virgin network and their analogue service is being switched off in line with the digital switch over. You'll either need a set-top aerial (if suitable for your location) or one up in the loft or maybe even outside. All depends where you are and how strong the signal is in your area.
If you want to use a length of left over Virgin co-ax to connect up your freeview box and TV it shouldn't be a problem as long as they can both take 'f' connectors.
I use my leftover Virgin coax cable for a temp connection lead with my satellite set up.
I like the crimped on F connectors much better than the twist on things that Sky use for there installs.
