Virgin grouter need HeLP
16 Jun 2005
Yorkshire
Hi guys,
First time ive done any grouting, on all tiles, used a grouting tool to push it in, worked well... But....
How long do i Leave it before washing the walls down?
Read the tiling sticky in the floor tiling section - all the info you need is there. I suggest if you've already applied the grout that you go and wipe the walls down ASAP! You might find that grout may have gone off already on the face of the tiles and it may be difficult to remove. Hurry up.
btw work the grout in along the lines then at a 90degree angle too clean with your washboy /sponge ...;)
if so refer to the wood blocks an bucketss an /elbow grease .....
see else where , my wonder is good ..
