I recently moved into a house with a Visonic Powermaster 10, it had been reset to defaults so I didn't have any problems configuring it. It was missing the keyfobs, so I splashed out and bought 2 as well as 2x MC302-E PG2 Contact Sensors.
I manually enrolled the keyfobs via the panel using the numbers (300-XXXX) on the back and they worked a treat.
When I tried to manually enroll the Contact Sensor (101-XXXX), it came up with 'Wrong-ID', I also tried to auto enroll via the button - but the panel did not detect it. The lights come up on the contact sensor and it flashes when I move the magnetic part near it so it appears to be working.
The same thing happens with the second Contact Zensor.
I then tried to enroll it with a 100-XXXX number and the panel registers a Contact Sensor but I get 'Not Networkd' - which is clearly right because 100-XXXX doesn't exist.
The contact sensors are all 868-1 which matches the panel - so I can't see where the problem could be.
Could this be firmware or am I missing something regarding compatibility and/ or installation?
Cheers,
YYo
Cheers,
YYo
