Visonic Powermax Complete Zone 29 Away/Disarm
12 Nov 2014
Hi from Andalucía and thanks in advance for your assistance.
I want to connect the Powermax Complete to another system where the PM is acting as a slave system.
I need to arm the system via Zone 29, witch I defined like stated in the installer manual as non-alarm zone and z-key was enabled. The resistances where set. Now the control panel should toggles between AWAY mode and Disarm. But all it's doing it says tamper open, tamper close. No arming or disarming. Any idea what I am doing wrong?
If its saying tamper open tamper close, then the trigger is controlling a tamper only and that wont set or unset.
I would have to look at the manual to check (not familar with this panel) what the settings should be, can you advise on what you have wired up and how.
Sorry and thank you
You might check the wiring 100 times, better you check it one more time. :)
My fought.... it was a false wiring, just follow the instructions in the manual and it works. And read carefully.
Bernd
