Hi, Symptoms indicating P.Vessel problem (rapid pressure rise when filling, drops to .4 bar in 24hrs). Am I right?, also steady drip from pressure relief pipe - worse when boiler running.
Can vessel be pressurised by myself (I'm pretty competent mechanically) Or do I need to send for the cavalry.
The reason being, I'm out of work at pres. and things are pretty tight.
Otherwise I dont mind the minor chore of topping up every morning, or is there a likelyhood of anything worse happening by leaving as is.
P.S. I've had some of the usual problems associated with the early 100's from week 1, and gather this is another common fault.
Glad of any advice, thanks Ian.
