vivaro van speedo stopped working
2 Feb 2010
Merseyside
Hi fellas
The speedo started jumping about a few weeks ago,now its stopped working altogether.
I believe it could be a sensor or wiring problem,is anybody aware of it beeing a common problem on the vivaro van.It's a 53 plate 1.9 diesel.
cheers
Not the simplest of fixes, I'm afraid......the speed sensor is either taken from the gearbox itself or if not that, then the ABS sensors.
For this one, I'd recommend specialist help.
John :)
if you feel confident enough jack it up and take the front wheels off, you can inspect the abs sensors and wiring easily.
The speed sensor is located low down at the rear of gearbox near the driveshafts. It is ususlly a black plastic "tube" type sensor with a 3-pin plug attached.
Have you tried putting the instrument panel into self-test mode to verify the operation of the gauges. ?
