Is the flow switch operated by the silver pin being pushed out when the pump is running and then retracting when the pump is off, and should I be able to see this movement happening as the pump switches on and off, I suspect the silver pin to be sticking in the out position, would this need a clean and a new diaphragm fitted to solve this problem.
