Failing to fire up. Pump runs. I manually activated the air pressure switch and it fired up. I checked for power getting to the fan, no power. Will it be the fan or the pcb?
just a stab in the dark i think that there is a resistor mounted to the underside of the combustion chamber make sure this hasnt failed as this will stop the fan from running
