Pilot light is on but im not getting full ignition when i turn heating on or put hot water tap on. Pressure is quite hight 2.5 / 3. Have bled radiators in case that helps but no joy. Any advice appreciated.
Elevated pressure will not have any detrimental effect on boiler operation.
Pilot will be on even when boiler is depowered (but boiler starts leaking within the combustion chamber if this is done).
Info given does not help at all.
Do you hear a hum from area behind the red switch?
Do you hear the fan running?
Have you had the boiler serviced (most I visit have been, but rarely as specified in the manual)
Flowmatic is a hard boiler to break. Lack of service often makes it sick. Good boiler that will come back to life if it is serviced.
My advise would be get the boiler looked at, Do NOT throw parts at the boiler needlessly and get an initial inspection before work commences on it. The inspection will tell you and the engineer what the nature of the problem is and also how other components are operating when boiler is functioning.
Do you hear a hum from area behind the red switch? - No there is very little noise coming from boiler. When its working fine it tends to make a bit of noise.
Do you hear the fan running? As above, very little noise coming from it all.Have you had the boiler serviced (most I visit have been, but rarely as specified in the manua) I had it serviced about 10 months ago, and again the winer previous)
Ive left a message for guy who serviced it last time to call me back. Still waiting so just wanted to see if anything that I could look at in meantime. Cheers.
